Activity Forums Avid Media Composer Avid 30 fps to 24 fps
  • Avid 30 fps to 24 fps
    Posted by Ryan Connors on September 29, 2014 at 9:40 pm
    I have footsge mistakenly shot in 30 fps for a 24 fps project. How do I make avid not apply the time warp effect, it looks choppy and pretty bad when it does. I’ve tried importing from a separate 30 fps project and no luck. Avid 5.5
    Shane Ross replied 11 years, 11 months ago 2 Members · 1 Reply
  • Shane Ross
    September 29, 2014 at 10:53 pm
    If you put any frame rate footage into the timeline that doesn’t match the project settings, you’ll get that green dot indicating it’s a different frame rate. it won’t be a Time Warp unless you promote it. But that is the best way to mix frame rates in Avid…import in a 30fps project, bring the bin into a 23.98 project, and cut.
    It will look a little choppy…after all, it wasn’t shot with conversion to 24 in mind. It wasn’t shot with 2/3 pulldown..it was meant to be 30fps. So it won’t EXACTLY match the 24fps stuff. The only way to get really close in that respect is to use a Terranex to convert the footage…or to use After Effects voodoo.
    Shane
    Little Frog Post
