Activity Forums VEGAS Pro AVI (Xvid) in Sony Vegas 7.0
  • AVI (Xvid) in Sony Vegas 7.0
    Posted by Jes11111 on November 15, 2007 at 5:00 am
    I’m desesperate to find a solution. When I try to put an AVI file (Xvid) into Sony Vegas 7, all I get in the timeline is the video part without the audio. Most of the videos are from downloaded tv shows. Those are playing fine in Window Media Player and DivX player. I’ve looked a lot of sites to find the problem and find a solution and it’s still doesn’t work.
    Here’s what I tried without conclusion:
    VirtualDub; when trying to convert a video, an error message appear : Couldn’t locate compressor for format XVID (unknow. VirtualDub requires a Video for Windows (VFW) compatible codec to decompress video. DirectShow codecs such as those used by Window Media Player, are not suitable.
    Four CC Code: I tried avic, changing the Xvid code. Worked fine until I clicked ‘play’. The video is reversed, doubled and has those weird colors and really bad quality.
    GSpot: It says I have all the codecs needed to play the video.
    I would really appreciate an answer, because I’ve been searching and trying for 2 days now. Also, I’m not a computer genius (more like basic). If you do have a solution, explain it lol.
    Matt Smitherz replied 18 years, 9 months ago 3 Members · 3 Replies
  • Laszlo Kovacs
    November 16, 2007 at 4:44 pm
    Vegas does not handle xvid/divx encoded files very well.
    Once I needed to edit a divx file, the only soultution was to reencode the divx file. I did with Virtualdub – a free software, google for it, you’re going to find it.
    I’ve set up virtualdub to output uncompressed audio and mjpeg video – of course you can try uncompressed video too.
    Hope I could help.
    By(t)e
    K.L.
  • Jes11111
    November 17, 2007 at 1:18 am
    Thanks, but if you actually read my whole post you’d see I already tried VirtualDub which does not seems to work…
  • Matt Smitherz
    November 25, 2007 at 5:54 pm
    Allo everybody, hope I can help.
    On my Vegas 8a Pro I could import split audio & video tracks Xvid files after installing the freeware RivaFLV Player (not because of the played but because of the inlcuded FFDshow codec which did the job.
    https://www.rivavx.com/index.php?id=422&L=3
    https://sourceforge.net/projects/ffdshow
    On a previous Vegas 6 installation I succesfully opened them following these tips for Casio MPEG4 videos.
    https://www.stevesforums.com/forums/view_topic.php?id=78626&forum_id=14
    https://www.click-now.net/forums/lofiversion/index.php/t4090.html
    I both cases problem was I could not split audio from video in vegas’ timeline, having only the audio track out of it.
    Cheers.
