Activity Forums Blackmagic Design avi with 6 channel audio, anyone found a quicker way to split the audio
  • avi with 6 channel audio, anyone found a quicker way to split the audio
    Posted by Duncan on August 31, 2005 at 2:43 pm
    hello.
    i need to split lots of avi with 6 channel audio, anyone found a quicker way to split the audio then in premiere manualy clicking, split to mono wavs. ? ? ? ?
    Any freeware/third party tools around?
    Thanks.
    Sameer Shrivastava replied 20 years, 11 months ago 3 Members · 2 Replies
  • Baz Leffler
    September 1, 2005 at 4:20 am
    Here’s how I do it….
    – Put the avi into the source window of Premiere
    – select File>export Audio
    – ensure ‘whole clip’ is selected
    – give it a name then…
    – open Audition
    – open the above file
    Now audition will create 6 mono wav’s.
    If I wan’t to create 3 x stereo’s I then bring them into auditions multitrack window and pan L/R each track pair and do a mixdown.
  • Sameer Shrivastava
    September 24, 2005 at 8:55 pm
    hi,
    select the clip in the project window then go to clips-> audio options-> “breakout to mono clips” should work fine
    sameer
