Activity Forums Apple Final Cut Pro Legacy AVI to MOV: 21fps and 24fps
  • AVI to MOV: 21fps and 24fps
    Posted by Alessandro Merletti de palo on August 20, 2009 at 11:12 am
    Hi everyone,
    I’m having a strange issue with some old videos I exported in .avi when working on a windows based system and they were 25fps, but once I saved them as QT mov and then imported them in fcp it loads them as they’re 24fps or even 21fps !!! And just for some of them, others don’t do that change at all!
    The result is the in and out point in the viewer show a part of the clip at 25fps, I drag it on the timeline and it still shows the same footage at 25fps, but when I export the edited timeline into a QT mov I got the video slipped because it was 21fps or 24fps!
    Is there a way to:
    see on the timeline directly the slipped video
    transform the 21fps and 24fps to 25 without quality loss
    export the video without the slipping change
    thanks everyone,
    A.
    Alessandro Merletti de palo replied 17 years ago 3 Members · 4 Replies
  • Jeremy Garchow
    August 20, 2009 at 11:33 am
    Use compressor to turn your AVI in to 25 fps qt movies.
  • Alessandro Merletti de palo
    August 20, 2009 at 3:24 pm
    Ok I tried and it works, now fcp “sees” it as 25fps, but when editing only the audio is at sync, while the video is out of sync in the timeline, but in sync when I export the video. So my main problem is still I can’t have the avi file able for editing.
    I’m still doubtful about:
    1) Why compressor understands both from the original avi file AND from the QTpro saved file that it is 25fps and not 24/21?
    2) Why only some of the files I converted were wrongly interpreted by fcp?
    3) Why after the conversion the new file according to fcp has one or two frames more than the original?
    After some analysis, it seems it’s a problem of MB/sec rather than fps, that leads fcp to interpret the files with a wrong fps rate. I made a short list of the files with mpeg streamclip info function:
    a) File converted to mov and interpreted by fcp as 24fps:
    Stream: BETTE2.avi
    Path: ~/Movies/old/avi 2 check/BETTE2.avi
    Duration: 0:03:55
    Data Size: 807.97 MB
    Bit Rate: 28.83 Mbps
    Video Tracks:
    DV – PAL, 720 × 576, 25 fps, 27.30 Mbps
    Audio Tracks:
    16-bit Little Endian stereo, 48 kHz, 1.54 Mbps
    Stream Files:
    BETTE2.avi (807.97 MB)
    MOV [compressor]:
    Stream: BETTE2-YT.mov
    Path: ~/Movies/old/avi 2 check/BETTE2-YT.mov
    Duration: 0:03:55
    Video Tracks:
    DV – PAL, 720 × 576, 4:3, 25 fps, 27.30 Mbps
    Audio Tracks:
    Stream Files:
    BETTE2-YT.mov (807.97 MB)
    fps okay, editing out of sync, export in sync with fcp audio
    MOV [QT]:
    Stream: BETTE2.mov
    Path: ~/Movies/old/avi 2 check/BETTE2.mov
    Duration: 0:03:55
    Video Tracks:
    Audio Tracks:
    Stream Files:
    BETTE2.mov (807.97 MB)
    fps interpreted as 24, editing out of sync, export in sync with fcp audio
    File converted to mov and interpreted by fcp as 21fps:
    Stream: capriBTS.avi
    Path: ~/Movies/old/avi 2 check/capriBTS.avi
    Duration: 0:04:29
    Data Size: 827.41 MB
    Bit Rate: 25.78 Mbps
    Video Tracks:
    DV – PAL, 720 × 576, 25 fps, 24.24 Mbps
    Audio Tracks:
    Stream Files:
    capriBTS.avi (827.41 MB)
    MOV [compressor]
    Stream: capriBTSb.mov
    Path: ~/Movies/old/avi 2 check/capriBTSb.mov
    Duration: 0:04:29
    Video Tracks:
    DV – PAL, 720 × 576, 4:3, 25 fps, 24.24 Mbps
    Audio Tracks:
    Stream Files:
    capriBTSb.mov (827.41 MB)
    MOV [QT]:
    Stream: capriBTS.mov
    Path: ~/Movies/old/avi 2 check/capriBTS.mov
    Duration: 0:04:29
    Video Tracks:
    Audio Tracks:
    Stream Files:
    capriBTS.mov (827.41 MB)
    fps interpreted as 21, editing out of sync, export in sync with fcp audio
    File mov converted from avi which is interpreted correcly [ original avi and this mov have same info, just a slight MB difference in filesize. Mov file obtained opening the avi with QT and saving as mov.]:
    Stream: Lotto Smorfia ORIGINAL.mov
    Path: ~/Movies/old/mp4tobe/Lotto Smorfia ORIGINAL.mov
    Duration: 0:06:07
    Data Size: 1.28 GB
    Bit Rate: 29.98 Mbps
    Video Tracks:
    DV – PAL, 720 × 576, 4:3, 25 fps, 28.45 Mbps
    Audio Tracks:
    Stream Files:
    Lotto Smorfia ORIGINAL.mov (1.28 GB)
  • John Pale
    August 20, 2009 at 4:58 pm
    Try using Cinema Tools to conform the erroneous clips to 25fps. All this will do is fix the Quicktime header that is causing the files to be played at the wrong frame rate.
    Of course, if the files were converted improperly and actually are 21 & 24 fps, this will not really fix it, but its worth a shot.
    August 22, 2009 at 4:34 pm
    I don’t understand.. if the QT header is wrong, why should it play correctly in QT and be recognized as 25fps by MPEG Streamclip? The same Cinema Tools reads it as 25fps..
