Activity › Forums › VEGAS Pro › AVI render introducing judder
  • AVI render introducing judder
    Posted by David Kostyk on May 10, 2019 at 5:20 am
    (First post. Sorry if I’m not following any protocols. I searched my issue but found nothing.)
    I have been attempting to edit the video content and replace the audio source of an old video file (live music stream circa 2006), then convert to lossless AVI so I can ultimately convert to h.264 (a codec unsupported in Vegas 12). Because my only available source uses Windows Media Video 9 (VC-1 WMV3), I cannot use “no-recompress long-GOP rendering” so using lossless AVI is an attempt to create a lossless intermediate file which won’t further dilute the compression (i.e. WMV3 > lossless AVI > h.264 should effectively yield the same results as WMV3 > h.264).
    Here’s where it gets weird: my source is not only awful WMV3, but also has an obtuse 20p frame rate. I assumed this would be okay because AVI supports any arbitrary frame rate down to millionths of a frame. However, when I encode WMV3 @20p > lossless AVI @ 20p, the result has clear judder. While the original has terrible video quality it at least has smooth motion; Not so for my resultant lossless AVI, which seems to have (at least) one or two interpolated frames per second creating judder. I’m at a loss as to what would be causing this because I assumed going 20p > 20p would yield a 1:1 result for frames. Turning on “Interleave every frame” seemed to result in a nominal judder improvement, but did not eliminate it (could also just be placebo effect?).
    Below are the technical details of the original file (I’ve removed the additional elementary video streams at “~~~~~”: they are just lower-quality fallbacks and are not relevant here).
    General
    Complete name : M:\Recordings\Live Music\Oysterhead\Oysterhead - 2006-06-16.asf
    Format : Windows Media
    File size : 638 MiB
    Duration : 1h 44mn
    Overall bit rate mode : Constant
    Overall bit rate : 855 Kbps
    Maximum Overall bit rate : 57.4 Kbps
    Movie name : Bonnaroo music festival
    Performer : AT&T
    Encoded date : UTC 2006-06-16 19:12:52.671
    Copyright : AT&T June 16, 2006
    Video #1
    Format : VC-1
    Format profile : MP@ML
    Codec ID : WMV3
    Codec ID/Info : Windows Media Video 9
    Codec ID/Hint : WMV3
    Description of the codec : Windows Media Video 9
    Bit rate mode : Constant
    Bit rate : 519 Kbps
    Width : 400 pixels
    Height : 300 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Variable
    Nominal frame rate : 20.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Language : English (US)
    Audio
    Format : WMA
    Format version : Version 2
    Codec ID : 161
    Codec ID/Info : Windows Media Audio
    Description of the codec : Windows Media Audio 9 - 32 kbps, 44 kHz, stereo (A/V) 1-pass CBR
    Duration : 1h 44mn
    Bit rate : 32.0 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Bit depth : 16 bits
    Stream size : 23.9 MiB (4%)
    Below are my current options for lossless AVI rendering.
    EDIT: I’m not using any video FX, just brief fading at beginning and end.
    Beyond Vegas 12, I’m also playing back both files in VLC Player 2.0.4.
    Hopefully I’ve conveyed my issue correctly. If any additional info (like an AVI file sample or even the original WMV3 file) is needed, I’m happy to provide. Thanks for reading and for any suggestions.
    George Dean replied 7 years, 4 months ago 2 Members · 11 Replies
  • 11 Replies
  • George Dean
    May 10, 2019 at 2:53 pm
    Hi David,
    Can you post a screenshot of your Project Properties?
    The wmv3 file is variable frame rate, although it isn’t reporting average or max, just nominal.
    What are you using to get the uncompressed avi and can you post a Mediainfo report on that?
    Best Regards……George
  • David Kostyk
    May 10, 2019 at 4:41 pm
    Thanks for the response! I had a suspicion variable frame rate might be the culprit, but I don’t like theorizing in help posts at the risk of my own ignorance contaminating others’ attempts to help me. ????
    Below are project properties. Though I’m sure they’re irrelevant, I’ve included audio properties JIC.
    I guess I don’t understand what you mean by “What [am I] using to get the uncompressed avi…?”: I’m just doing a Vegas 12 “Render As…” using the rendering properties in my original post. Below is the MediaInfo for the resulting file:
    General
    Complete name : V:\Oysterhead [new mix].avi
    Format : AVI
    Format/Info : Audio Video Interleave
    Format profile : OpenDML
    File size : 42.2 GiB
    Duration : 1h 42mn
    Overall bit rate : 59.1 Mbps
    TCOD : 0
    TCDO : 61276000000
    Video
    Format : RGB
    Codec ID : 0x00000000
    Codec ID/Info : Basic Windows bitmap format. 1, 4 and 8 bpp versions are palettised. 16, 24 and 32bpp contain raw RGB samples
    Duration : 1h 42mn
    Bit rate : 57.6 Mbps
    Width : 400 pixels
    Height : 300 pixels
    Frame rate : 20.000 fps
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 24.000
    Stream size : 41.1 GiB (97%)
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : 1
    Duration : 1h 42mn
    Bit rate : 1 411.2 Kbps
    Bit depth : 16 bits
    Stream size : 1.01 GiB (2%)
    Alignment : Aligned on interleaves
    Interleave, duration : 50 ms (1.00 video frame)
    Interleave, preload duration : 50 ms
    Hope that sheds some light!
  • George Dean
    May 10, 2019 at 5:02 pm
    David, please excuse me, but I am a bit confused, so correct me if I’m wrong….
    You are bringing in the 20 fps WMV3 file into Vegas 12, then rendering out a uncompressed avi.
    From that avi you are going to render out an mp4.
    I don’t understand why you are rendering the uncompressed avi, if the end results are an mp4. Why not just render out the mp4 from Vegas 12 using the WMV3 as the source media?
    I would certainly like to test a sample of your WMV3, but the file you used for the Mediainfo above is 638 MB, which is far to large for me to download on my restricted monthly data plan. If you had a sample that was say 50-100 MB that would be doable. Do you have a small sample?
  • David Kostyk
    May 10, 2019 at 5:36 pm
    Sorry that I didn’t explain that completely:
    • I’m ultimately looking for an MKV file with h.264 video and my newly mastered audio (PCM w/ AC-3 fallback). But:
      • HandBreak (v0.10.5.0) doesn’t handle PCM properly (always converts it to AC-3).
      • Muxing the audio with h.264 video doesn’t sync properly in Hybrid (v2019.05.05.1).
      • Muxing with MKVToolNix (v33.1.0) yields the same sync issues.
      In all above examples, I also lose my intro and outro video fades.
    • While I considered just abandoning h.264 MKV for generic MP4, Vegas 12 doesn’t appear to support variable frame rate for that codec (unless I’m missing something). Therefore, a Vegas 12 MP4 will still result in judder, yes? While h.264 supports variable frame rates by default.
    • My intent was then to make a 480×360 blow up for YouTube publishing (which I don’t believe supports 400×300 resolution) plus an iPod encoding.
    All of this I incorrectly assumed would be best achieved by going uncompressed AVI, then making each file for different purposes from this otherwise “lossless” master.
  • David Kostyk
    May 10, 2019 at 5:46 pm
    As for a sample, I cannot think of a way to provide one. I don’t have anything that will just “trim” a WMV3 .asf file. And I can’t find a plausible format to use in Vegas 12 that supports variable frame rate.
  • George Dean
    May 10, 2019 at 6:02 pm
    David is your project a one time deal, or do you have other WMV3 videos to convert? Is your operating system 32 or 64 bit? If it is 64 bit, can you download the free trial version of Magix Vegas Pro 16? I have an idea, although it may make no difference. If you had a small file WMV3, I would test this myself, but I don’t think that is the case, so maybe testing on your system.
  • David Kostyk
    May 10, 2019 at 6:38 pm
    I have a few more similar files for which I’d be doing a similar operation.
    I run x64. I do have to leave for work soon, but I can download the trial tonight. If you leave instructions for what you’d like me to try, I’d be happy to give it a go.
  • George Dean
    May 10, 2019 at 7:04 pm
    David I was thinking if you could put your files on a disc or thumb drive and mail them, I could possibly finish them for you in Vegas Pro 16, if that version works better than 12, if the source media is not sensitive and you feel comfortable with me seeing it, and if you are in North America. Those are a lot of if’s. But they rely on Vegas Pro 16 being a better platform for getting results and the trial version being free, it is just the cost of your time to test it out.
  • George Dean
    May 10, 2019 at 8:08 pm
    David, if you do try the Vegas Pro 16 trial, check that it is the latest build 424 and Go > Options > Preferences > General tab and check if there is a check mark in the box ‘Favor audio sync when playing Variable Frame Rate (VFR) media’, which should be checked, but I do not remember is it is by default.
  • David Kostyk
    May 11, 2019 at 3:13 am
    Well, your suggestion allowed me to fall ass-backward into my answer: AVC, which is another name for MPEG-4p10, aka h.264. ???? I just looked for any codec with deterministic frame rates and an “Allow source to adjust frame rate” toggle, did an AVC test sample and VLC was kind enough to remind me that AVC is h.264.
    I’ll just mux in the PCM and AC-3 audio streams.
    Remaining question though: what is a reasonable “Number of reference frames”? HandBrake and Hybrid (or ffmpeg maybe) uses 3 by default and HandBrake claims 6 is the sane upper limit. Any benefit or detriment to upping it higher than 3?
