Activity › Forums › Adobe Premiere Pro › .avi import to PPCS3, movie length cut off
Ben Logan replied 18 years, 7 months ago 4 Members · 17 Replies
Mike Velte
December 14, 2007 at 6:17 pmI just did a screen capture using Windows Media Encoder 9…4 minutes long and all imported fine into CS3. What app are you using to screen capture?
Bruce Liddil
December 14, 2007 at 9:27 pmMike,
The video files were captured with a capture utility created in-house by one of our programmers. I’m wondering if there is something about how his program is written that is friendly with PP1.5, but not PPCS3. The programmer is looking in to this. I think the question is: what is different between PP1.5 and PPCS3 in terms of how it handles these video files?
Bruce
Mike Velte
December 15, 2007 at 11:49 am[Bruce Liddil] “how it handles these video files?”
Obviously, but we dont know what is the difference. Why not use Microsoft’s free encoder or even better, Camtasia 5.
Bruce Liddil
December 17, 2007 at 2:51 pmHi Mike,
For a lot of reasons, we need to use the video capture utility developed in-house. We are doing scientific research in the area of human factors of flight systems that requires requires a lot of custom built systems to interact. Also, we need to turn around long movies (30 to 60 minutes) fairly quickly. Because of that, Microsoft or Camtasia’s product aren’t an option. Actually, we used My Screen Recorder in the prototype stage, but we needed to write our own capture utility to get the functionality we needed. At this point we’re looking at buying more licenses of PP1.5, since we know it works. Might be easier than trying to figure this out!
Bruce -
Ben Logan
January 28, 2008 at 3:33 pmHi Mike/Bruce
Did you guys manage to find a solution for this?
We have a 1.4gb movie that runs for about 15mins and was recorded using a tool called Morae by Techsmith. It uses its own codec https://www.techsmith.com
We are finding that when we play the avi in Windows Media Player the length is fine. When we import into PPCS3 we get a file lenghth of 43 seconds only?
The output of the properties from PPCS3 are below:
File Path: E:\D
Type: AVI Movie
File Size: 1.4 GB
Image Size: 1280 x 1024
Pixel Depth: 1280
Frame Rate: 10.00
Source Audio Format: 22050 Hz – compressed – Mono
Project Audio Format: 48000 Hz – 32 bit floating point – Mono
Total Duration: 00;00;43;13
Average Data Rate: 33.2 MB / second
Pixel Aspect Ratio: 1.0AVI File details:
Contains 1 video track(s) and 1 audio track(s).
Interleave: 1 : 9.86Video track 1:
Size is 1.40G bytes (average frame = 163.91K bytes)
There are 113 keyframes, 8912 delta frames.
Frame rate is 10.00 fps
Frame size is 1280 x 1024
Depth is 32 bits.
Compressor: ‘tscc’, TechSmith Screen Capture CodecAudio track 1:
Size is 3.85M bytes
Rate is 22050 samples/sec
Sample size is 16 bits
Compatible compressor: Microsoft GSM 6.10
Compression ratio is 9.85:1Any ideas how we can get round this?
Cheers
Ben
Bruce Liddil
January 30, 2008 at 4:19 pmHi Ben,
Sorry it has taken so long for me to reply. I’ve been out of town.
We never did solve this problem. Our programmers think that Premiere Pro CS3 doesn’t like our codec (developed in house).
Premiere Pro 1.5 doesn’t have a problem, so we switched back to that. 🙁 Not the greatest solution, but gets the job done for us.
I’m sorry I don’t have a better answer for you. If I find further information or a solution, I’ll let you know.
Good luck!
Bruce
Ben Logan
January 31, 2008 at 9:12 amHi Bruce
Thanks for coming back to me!
We ended up going back to the original usability company and obtaining a copy of the orginal source footage in another format. The problem was caused by the compression and codec used by Techsmith. Adobe Premiere CS3 was not liking it!
Cheers
Ben
