Activity Forums VEGAS Pro AVI files not working on SV
  • Paige Karmen
    December 11, 2010 at 4:19 am
    Another thing to add, when i had K-Lite codec Pack installed, it would play ing Home Cinema, and in Windows Media Player, Not sure about Windows Photo Gallery… that does play some videos… but the only two things it wouldn’t play in is Sony Vegas and Windows Movie Maker, i’m okay with just being able to mak vid’s in WMM, but i really would like to use SV.
  • Paige Karmen
    December 11, 2010 at 5:17 am
    Okay I post multiple things at a time… but that’s only because I really want to figure this out, the sonner the better, like i know 2 hours is almost impossible, but it would be a miracle if we got it working like a while before then.
    Anyway, When i went to open the File, and wait it says in the box below…
    File Type: Video for windows Streams: 2
    Video: Stream attributes could not be Length:
    Media: Stream attributes could not be Length:
    I don’t know if this would be helpful, but it says that for all my AVI files.
  • John Rofrano
    December 11, 2010 at 3:59 pm
    [Paige Karmen] “Okay i have a 64-bit computer, a 64-bit Sony Vegas installed, and i had K-Lite Codec pack, and every single Codec I installed wouldn’t work.”
    If you are using the 64-bit version of Vegas Pro you will need a 64-bit codec to go with your video files. Chances are a 64-bit codec does not exist for the files you are using which means these files will never work with Vegas Pro 64-bit. You need to use Vegas Pro 32-bit to work with 32-bit codecs.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • John Rofrano
    December 11, 2010 at 4:01 pm
    [Paige Karmen] “Anyway, When i went to open the File, and wait it says in the box below…
    Media: Stream attributes could not be Length:”
    You need to open the file in GSpot to see the codec, not Vegas.
    ~jr
  • John Rofrano
    December 11, 2010 at 4:02 pm
    [Paige Karmen] “Another thing to add, when i had K-Lite codec Pack installed, “
    It should be pointed out that using codec-paks has been know to cause Vegas not to work properly so they are not recommended to be installed on video editing workstations. One install the codecs you need for the files you are working with.
    ~jr
  • Paige Karmen
    December 11, 2010 at 9:22 pm
    Where do i find a codec for 64-bit Sony Vegas?
  • Paige Karmen
    December 11, 2010 at 9:24 pm
    I know that, that’s why i didn’t think it would be heplful, but i threw it in there because i’m trying to get it to work with Sony Vegas!
  • Paige Karmen
    Okay, then what?
  • Paige Karmen
    December 11, 2010 at 9:39 pm
    https://www.codecguide.com/klcp_64bit.htm
    I’ve already installed this and it didn’t work, i’m currecntly trying it again. But If it doesn’t work. Well that’s exactly what i mean!
  • Paige Karmen
    December 11, 2010 at 10:58 pm
    So far, it’s worked on one file… Thanks, i think i’ve found what’s wrong! Although the second one opens video, but is completely black when i play it on SV, although it needs DivX 4 {OpenDivX} installed… so the only thing i think that you could help me with is finding DivX 4 {OpenDivx} for 64-bit!
Page 2 of 3
