Activity › Forums › Apple Final Cut Pro Legacy › .avi files in FCP
  • .avi files in FCP
    Posted by Jack Entonces on May 24, 2008 at 3:26 pm
    i received a CD disk with a bunch of .avi files to use in my project.
    But I was not able to open them in FCP. I tried to convert them to .mov files within
    FCP using ‘Export” in the File menu, but was not successful. Maybe I was using the wrong
    settings, codec. Is there some way to open and be able to edit with an .avi file in FCP??
    thanks
    Kevin Monahan replied 18 years, 4 months ago 3 Members · 2 Replies
  • Colin Mcquillan
    May 24, 2008 at 3:48 pm
    You should try to always convert to .mov’s that match your sequence settings before bringing them into FCP. Even though, if you have the correct codecs installed that match the one that the avi was created with, it can play as is in FCP.
    If you can’t watch the .avi’s in QT player, then you don’t have the right codecs installed on your computer.
    Find out what program/codec was used to create the files.
    Colin McQuillan
    Van BC
    Octo 3.2, 8gig, 8800GT, 2×23″ ACD, 2TB G-Speed eS, Kona LHe, JVC DT-V24L1UA, Mackie 1202-VLZ3, KRK Rokit5’s….
    MBP 2.4, 4gig , 2xLacie Quadra 500gig….
  • Kevin Monahan
    May 24, 2008 at 4:34 pm
    Google Flip4Mac. That’s what you want to do. A search on the word “.avi” would have gotten this info as well. Quite a common Q.
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
