Activity Forums Adobe Encore DVD AVI files corrupt???
  • AVI files corrupt???
    Posted by George Cox on October 18, 2008 at 5:21 pm
    Following problems with my computer [XP] I have had to reinstall EncoreDVD version 1. Every time I try to import an .avi file as an asset I get the following message. Could not import the file. May be corrupt or the type may not bee supported.
    I have tried to import numerous files that I have used before with the same result
    I have tried reinstalling the programme and it is still the same.
    Any help that you can give me would be appreciated.
    Also. will Encore V1 run on a Vista machine?
    Thank you,
    GEORGE.
    George Cox replied 17 years, 11 months ago 3 Members · 4 Replies
  • Joe Bowden
    October 19, 2008 at 12:46 am
    Sounds like you may be missing a codec.
    Encore version 1 was released in 2003, several years before Vista. Last I knew, Encore 1.0 only supported Windows XP.
  • George Cox
    October 19, 2008 at 12:53 am
    I managed to find my V2 and have installed that so problem solved.
  • Richard Talmage
    October 22, 2008 at 8:05 pm
    I have the same problem. I am picking up the same response from an avi file that encore says it is corrupt. Any idea what is going on with this clip?
    Richard Talmage
    Cape Cod, MA
  • George Cox
    October 22, 2008 at 9:08 pm
    Richard,
    I never cured it. I was lucky that I found my Version 2 disc and was able to reinstall it so I did not pursue it.
