Activity Forums Apple Final Cut Pro Legacy avi exports to quick time jittery??
  • avi exports to quick time jittery??
    Posted by Zeliha Bozkurt on August 17, 2007 at 3:43 pm
    Hi
    I have a load of avi clips I need to use in my Final Cut Project. When I export them to avi the image gets all jittery
    Is there another way of exporting these avi’s so that the image is smooth.
    PS: tried to export using compressor but the outcome was still jittery.
    Zee. 🙂
    Mark Maness replied 19 years, 1 month ago 2 Members · 1 Reply
  • Mark Maness
    August 17, 2007 at 4:01 pm
    That sounds like a field issue. Somewhere the wrong fields are being chosen when exporting to AVIs.
    Tell us more about your video clips. What are the original clips in FCP? What codec and screen size?
    The issue usually occurs because SD video is 720×486 lower field. AVIs are traditionally, if large size, being 640×480 upper field. This can be a real problem when exporting.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
