Activity › Forums › Boris FX Particle Illusion › AVI Export ain’t working
  • AVI Export ain’t working
    Posted by Enrico01 on May 18, 2007 at 8:58 pm
    Hi guys.
    The program itself is quite nice, but I have problems exporting my finished project as AVI file. Whatever codec I try, it doesn’t work.
    Xvid –> “Error initializing AVI”
    DivX ain’t even on the list of available codecs, even after reinstalling.
    Cinepak by Radius –> Working, but the quality ain’t good and all of my other codecs don’t support so I can’t recode it.
    I have only problems with all the other codecs as well: either black video stream or an empty file.
    I really don’t know what to try anymore. Hope someone can help me.
    Regards,
    Enrico
    Alan Lorence replied 19 years, 4 months ago 2 Members · 3 Replies
  • Alan Lorence
    May 19, 2007 at 12:15 pm
    You may be using weird stage sizes. As a test, try 320×240 and see if that works. If it does, remember that you have to make the stage window large enough to fit your stage size at 100% zoom. If you have the stage set to 640×480 for example, but the stage window is too small, the output size (shown in the output options dialog) might be something weird like 521 x 377, and most codecs won’t like that weird size.
    Alan.
    http://www.wondertouch.com
  • Enrico01
    May 19, 2007 at 1:48 pm
    Thank you. It now works with Xvid. 🙂
    Still, it does not work with Uncompressed, which I think is very weird (I only get a black video, or, if I use “Software Rendering” or tick “Don’t use texture RAM for bg images”, colors are messed up totally).
    And it won’t recognize DivX.
    But well, I can export my videos using Xvid now, so those problems are not that important anymore. 😉
    Regards
  • Alan Lorence
    May 21, 2007 at 11:12 am
    Don’t use uncompressed — it doesn’t work for some people with pIllusion for some reason.
    Download and use Huffy UV instead. It uses lossless compression.
    Alan.
