Activity › Forums › Boris FX Particle Illusion › AVI and alpha
  • Posted by Matt Adam on August 12, 2008 at 6:06 pm
    Hi, I’m new to this and Particle Illusion.
    I’ve been reading that one is not allowed to use .AVI and alpha together in an export. That I have to export as .PNG or such in order to include and alpha channel.
    My question is that I usually pick uncompressed AVI as my file export, and then that allows me to include an Alpha channel, and then I just import into Adobe Premier and work with it like any other file. Alpha included. Is there something wrong with using uncompressed AVI from the export options? Is it a size issue? (I noticed the file is 10 times as large than a DV AVI with no alpha channel)?
    And forgive my ignorance, I’m just a composition guy, not a tech guy. Still trying to figure it out and pull my weight around here.
    Thanks for letting me know.
    -Matt
    Alan Lorence replied 18 years, 1 month ago 2 Members · 1 Reply
  • Alan Lorence
    August 12, 2008 at 8:27 pm
    That was true in older versions, but AVI can use alpha now (if you’re using 3.0.2 or newer).
    Also, don’t use uncompressed AVI. Use a lossless codec like Huffyuv or Lagarith. They work better in pIllusion, and they take up less drive space. And they don’t lose any quality (it’s lossless compression, like a ZIP file).
    Alan.
    http://www.wondertouch.com
