Activity Forums Apple Final Cut Pro Legacy AVCHD window dub/timecode
  • AVCHD window dub/timecode
    Posted by Scott Allman on June 5, 2009 at 12:53 pm
    Hello,
    I am trying to make a timecode window burn of some AVCHD clips and if I use either the TC reader or TC generator from the Video Filters, each clips starts from 00:00:00. Is there a way to work around this and have all the clips numbered in sequence? I mean sequential timecode.
    Scott Allman
    Scott Allman replied 17 years, 3 months ago 2 Members · 2 Replies
  • John Fishback
    June 5, 2009 at 2:03 pm
    If you have a bunch of clips strung out along a timeline you can nest them, and then apply the t/c reader filter to the nest. You should get a t/c burn with the time taken from the timeline.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Scott Allman
    June 5, 2009 at 2:20 pm
    I knew there was some kind of work around.
    Scott
