Activity › Forums › Apple Final Cut Pro Legacy › AVCHD to SD DVD PAL + NTSC
  • AVCHD to SD DVD PAL + NTSC
    Posted by Christine Tervey on October 11, 2010 at 4:07 pm
    Hello,
    I am musician and started working with FC Studio 7 past month. I cut AVCHD footage in ProRes 422 HQ sequences (1920×1080, 25 fps, PAL not NTSC)
    I would like to output them (80 minutes) as DVD SD in both PAL and NTSC as well.
    I have already tried many settings this week, but the results do not look very good on a TV cathode monitor. There are horizontal lines in contours of moving objects. So I think I have an interlacing problem with my upper field dominance in my HD cut sequences and the lower fields for SD DVD.
    I tried the following workflows in several combinations:
    1)
    export of a self-contained QT movie, current settings
    export of a QT movie, downscaled to 720, no compression
    –> in Compressor: conversion with several presets for DVD Studio, or self-modified in regards to the field dominance.
    –> importing those m2v-files into DVD Studio, (encoding preset for the field dominance left at “auto”)
    2)
    something that was called Bonsai method
    copying the HD clips/ sequence into a SD sequence (CCIR 601 5:4, anamorphotic, upper field, apple prores 422 HQ)
    –> export of a self-contained QT movie, current settings
    –> in Compressor: as discribed in 1)
    As I am getting more and more confused the more I try. What would be the best workflow and settings?
    My second problem: What would be the best way to convert from PAL to NTSC ? My film is a live recording of a concert and has fast movements, so picture and sound should be 100% synchronized.
    I would be grateful for some help.
    Regards from Germany
    Mahesh Dood replied 15 years, 11 months ago 2 Members · 1 Reply
  • Mahesh Dood
    November 4, 2010 at 5:13 pm
    hi
    i have also posted a similar mail. how to convert AVCHD PAL to DV PAL?
    try first converting the AVCHD PAL material to prores, next try converting the prores material back to DV PAL. i am using compressor, see if it works?
    then convert DV PAL to m2v for SDDVD, it should work
    mac
