AVCHD to DNxHD or DNxHR Color Shift in Premiere CC 2015?
I have AVCHD 29.97 1080p footage from a Phantom 3 Pro Quadcopter. I used MPEG Stream Clip and After Effects CC 2015 to transcode clips to edit with in Premiere. I thought the clips looked brighter once in Premiere so I imported an original AVCHD clip and compared the two. The DNxHD clip is brighter; it’s blown out a little bit. I also tried DNxHR. It looks the same as the DNxHD.
Has anyone else experienced this? I did a search but didn’t really see anything.
ThanksP.S. I’m on Windows 10.
