Activity › Forums › Adobe After Effects › AVCHD Quality Loss in AE
Posted by Scott Cundy on April 13, 2009 at 11:08 pmI am using the Sony HDR-SR11e. When I play the videos directly from the camera using the AVCHD Player that came with the camera, the quality is considerably better than when I import the .m2ts files into AE. Does anybody know why this is or have a solution?
Cheers, Scott.
Kevin Reiner replied 17 years, 5 months ago 2 Members · 3 Replies -
Kevin Reiner
April 14, 2009 at 12:41 amProbably a color space issue. Make sure your project color space settings and footage color space settings are the same. Specifics can be found in the manual or by searching the Cow for “Color Space”.
System Setup (for a more detailed list, see my profile)
HARDWARE
Mac Pro 2 x 3 GHz Quad-Core Intel Xeon
9GB Memory
Two 16x SuperDrives
Dual-channel 2Gb Fibre Channel PCI Express card
Apple Cinema HD Display (23″ flat panel)
ATI Radeon X1900 XT Graphics Card
AJA Kona LHe SD/HD capture card
Apple Xserve Raid 5.6TBSOFTWARE
Mac OS X 10.4.11
Final Cut Pro Studio 2
After Effects CS3
Photoshop CS3
Illustrator CS3
Boris Continuum 5
Sapphire Plug Ins
Roxio Toast
Digital Anarchy Anarchist Suite
ParticleIllusion 3.0
Trapcode
Zaxwerks -
Kevin Reiner
April 14, 2009 at 2:17 amThat’s my initial guess. I would need more info on what you mean by bad quality. Color/gamma shift? Blurry? Pixelated? Interlaced?
Is the resolution set to Full and the layer’s quality set to best. If yes, then it is probably something that interpret footage would correct.
-Kevin
HARDWARE
9GB Memory
Two 16x SuperDrives
Mac OS X 10.4.11
After Effects CS3
Photoshop CS3
Illustrator CS3
Boris Continuum 5
Sapphire Plug Ins
Roxio Toast
Trapcode
Zaxwerks
