Activity › Forums › Apple Final Cut Pro Legacy › avchd, prores and interlacing
  • avchd, prores and interlacing
    Posted by David Attali on March 3, 2010 at 12:08 pm
    Dear Cow,
    I am strugling with the question of interlacing and hope a wizard can help.
    Project: broadcast /two output: mov and digibeta
    Media capture: AVCHD 1080i /prores422
    question: footage looks awful on 1080 p full hd display with the shadow effect of interlacing ( field dom: upper); do I absolutely have to deinterlace with filter? I thought “I” should play well on full hd (p) TV ( like there is an converting engine in tv) display….
    By deinterlacing, do I not loose quality?
    Basically, how to deal with avchd and interlaced footage for broadcast”? My photo jpeg footage is progressive and looks fine….
    thank you very much !
    DA
    David Attali replied 16 years, 7 months ago 4 Members · 10 Replies
  • 10 Replies
  • Jeremy Garchow
    March 3, 2010 at 1:37 pm
    How are you connected to the monitor?
  • Arnie Schlissel
    March 3, 2010 at 1:53 pm
    [David Attali] “By deinterlacing, do I not loose quality?”
    Yes, you do. You throw away half the resolution of your picture.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • David Attali
    March 3, 2010 at 1:57 pm
    Hi Jeremy,
    Thanks for your question.
    HD display connected trough hdmi
    my config: i mac 2.7 gz 4 gb ram 320 gb HDD
    interlacing also is very visible on i mac display…. what can i do?
    D
  • David Attali
    March 3, 2010 at 2:00 pm
    Hey Arnie,
    thanks. I am confused, am I doomed to either interlaced or half quality when NOT playing on CRT display?
    Basicaly, how to get my interlaced footage looked stunning on a flat display?
    Merci,
    D
  • Jeremy Garchow
    March 3, 2010 at 5:45 pm
    [David Attali] “HD display connected trough hdmi “
    You need a true capture device that you send a proper video signal and not an HDMI bastardization over DVI.
    Jeremy
  • Michael Gissing
    March 3, 2010 at 8:11 pm
    If your output is digi beta, then your final is standard def and therefore interlaced for broadcast. Do not deinterlace.
    I suspect your problems are in the way you are connecting to your monitor. You need a proper interface like Kona, Matrox or Decklink to output to an external monitor.
  • David Attali
    March 4, 2010 at 10:25 am
    Merci Michael..
    So I’ll keep interlaced for this ..although, satelite broadcast ends mostly on flat progressive screens this days.
    so if i-> goes to p and I do not want to loose quality,any possible workflow?
    Thanks a bunch
    D
  • Arnie Schlissel
    March 4, 2010 at 1:36 pm
    [David Attali] “so if i-> goes to p and I do not want to loose quality,any possible workflow?”
    Shoot progressive.
    Arnie
  • Jeremy Garchow
    March 4, 2010 at 5:27 pm
    [David Attali] “although, satelite broadcast ends mostly on flat progressive screens this days. “
    This is true, but there’s no 1080p broadcast spec yet. Flat screens are setup to deal with 1080i material.
    Jeremy
  • David Attali
    March 5, 2010 at 1:06 am
    Thanks for insight jeremy, appreicate it!
    Cheers,
    D
