Activity Forums Adobe Premiere Pro AVCHD problem in premiere after Cineform HD link conversion.
  • AVCHD problem in premiere after Cineform HD link conversion.
    Posted by Billy Payn on June 16, 2009 at 5:05 pm
    Hi
    I’ve taken AVCHD video files from Sony’s HXR MC1P, converted them with Cineform HD link and imported into Premiere, and am having a problem.
    When I view the converted files in Windows Media Viewer, they look OK, as I would expect, though the camera isn’t as sharp as I’d like, any movement gives lots of blur.
    The thing is, when I import to Premiere CS3 (with the lates updates) there are some worrying effects I can’t get rid of.
    I tracked the camera past the upright stair rods, premiere is doing some kind of ghosting on the vertical rods. It looks like a double image, there seems to be two of each rod, both of them slightly opaque, and they make a solid where they overlap, leaving one thin stair rod, and some see through parts on both sides. The faster the movement, the more they spill to the sides, ie the wider the whole rod is, and the narrower the overlapping part is, giving the impression of a very thin rod. This effect is visible on any upright subject to movement.
    When I play the video at normal speed, it’s not that noticeable, though now I know it’s there I can see it. When I slow down the video, it’s really glaringly annoyingly in your face ruining the whole deal obvious.
    It looks as though this is a premiere issue as it’s not happening in Windows Media Viewer (it does happen in after effects though)
    I’ve tried converting to 1920 progressive, 1920 interlaced, then importing with both fields dominant, 1440 – both ways as well tried losing flicker, frame blending on and off, Quicktime with all the variables, the only thing that it wont do is deinterlace- it crashes premiere. Also tried the different quality settings in HD link and on the camera. Can’t find anything that makes it go away.
    Has anyone else encountered a similar problem to this?
    Any help appreciated.
    Sytem is a dual quad core xeon 2ghz with XP 64bit 8gig ram, Premiere Pro CS3 cineform Prospect 4K 4.2
    Billy
    Hope no one minds I’ve posted this on the Adobe Premiere forum as well.
    Billy Payn replied 14 years, 11 months ago 3 Members · 4 Replies
  • Bren Wilson
    October 3, 2011 at 12:18 am
    I too am having this issue and am becoming very frustrated.
    I have tried a variety of “solutions” to no avail!
    http://www.brenwilson.com
  • Alan Husband
    October 3, 2011 at 7:00 am
    The one thing you don’t mention is the framerate.
    What is the framerate of the original footage? What is the framerate of the Cineform intermediate? What is the framerate of the Premiere project?
    It sounds like a framerate mismatch is occuring at some point in the workflow, probably in Premiere if the Cineform intermediate doesn’t have the problem during regular playback in a media player.
  • Alan Husband
    October 3, 2011 at 7:04 am
    I didn’t notice this was a necro’d thread…..
    If you are having the same issue as the OP, check your framerates are matching.
  • Billy Payn
    October 3, 2011 at 9:53 pm
    Wow, thanks for the reply, I gave up on this camera a couple of years ago as it had so many problems this being one of them.
    The MC1P in my view should never have been marketed for the extreme sport market when it had an optical image stabilizer.
    Im pretty sure I had the framrates lined up as a basic project setting.
    Ive had much more success using a gopro for anything Id have used the MC1P for with no other issues.
    Thanks for responding.
