Activity Forums Apple Final Cut Pro Legacy AVCHD imports jittery on FCP, but OK on iMovie
  • AVCHD imports jittery on FCP, but OK on iMovie
    Posted by Ace Billet on May 18, 2009 at 6:04 am
    Hi folks
    I’m importing HD footage (AVCHD) from Sony HDR-SR11 Handycam.
    It’s NTSC footage. When the footage imports to FCP (in Quicktime)
    it plays buggy, frames jump back and the whole thing looks like
    an episode of “When Drop Frames Attack”.
    I tried “All” (namely 2) import codecs: Apple Intermidate and Pro Res422.
    Both resulted in the same unusable footage.
    I also ticked the “Drop Frame” box.
    And as always, when FCP FAILs, I tried importing the same footage on iMovie. Came out perfect, complete with files names etc.
    Anyone else had problems importing AVCHD footage ?
    My system: MacPro2 / FCP 6.0.5 / iMovie 09
    Adam Canady replied 17 years, 3 months ago 3 Members · 3 Replies
  • Walter Biscardi
    May 18, 2009 at 12:31 pm
    What hard drive array are you using?
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Ace Billet
    May 18, 2009 at 12:34 pm
    I’m not using a HD array, I’m just capturing to the MacPro’s internal SATA HD (1tb).
    Also, the import is fine when I’m using my MacBook Pro (1st Generation), and capturing to FireWire 400 drives.
    <== BilletHQ | Creative that Goes to 11 ==>
    http://www.billethq.com
  • Adam Canady
    May 30, 2009 at 5:04 am
    Hey I have the same problem. Tried all the codecs and the drop frame box, etc. but there is this program Voltaic HD which I read about on a macrumor forum on this topic that will convert the video but it takes up to 12 times as long which is no good. high quality and retains the 5.1 channel sound though. another downside is that its $30. lame. i hope apple releases some more codecs/is there a way to put other, working codecs into fcp? how come imovie will work and not fcp? is there a way to copy the settings from imovie to fcp?
