Activity › Forums › Apple Final Cut Pro Legacy › AVCHD FCP 6.0.2
AVCHD FCP 6.0.2
Posted by Scott Sutter on January 23, 2008 at 3:32 amI have AVCHD files transfered off the card, and put into a folder on the desktop. I launch FCP 6.0.2 running on an intel 2.66 quad, with the newest version of the OS (10.4.11) as well as the newest version of quicktime. For some reason when i open log and transfer and try to select the folders that these files are in nothing happens and FCP wont recognize the files? I know ive done it this way before but this was a few months back and i was running an older version of FCP and operating system. Anybody have any ideas. Thanks
Jeremy Garchow replied 18 years, 5 months ago 4 Members · 18 Replies -
Jeremy Garchow
January 23, 2008 at 3:50 am1)make sure you have the codecs/drivers from Panasonic:
https://www.panasonic.com/business/provideo/support/software_downloads.asp
2) Upgrade fxfactory if you have it
https://docs.info.apple.com/article.html?artnum=307062
3) uninstall Perian if you have it
https://docs.info.apple.com/article.html?artnum=306922
Scott Sutter
January 23, 2008 at 12:58 pmThank you very much for the speedy response, and an answer to the problem!
Scott Sutter
January 23, 2008 at 4:06 pmThe driver download from panasonic. I didint have perian, and i have the newest version of fx factory. Thanks again
Bill Bilowit
March 2, 2008 at 11:19 pmRegarding ingest of AVCHD folder, Jeremy said:
“1)make sure you have the codecs/drivers from Panasonic:
https://www.panasonic.com/business/provideo/support/software_downloads.asp“
Hi Jeremy, I’m having some trouble myself with this, and it’s not Perian or fxfactory. So on the link above, what software relates to AVCHD, other than a P2 transcoder for Windows?
Thanks…
Jeremy Garchow
March 3, 2008 at 1:35 amHello Bill. What kind of camera are you coming from and what’s not working?
Jeremy
Jeremy Garchow
March 3, 2008 at 4:40 amThanks, just making sure it wasn’t a DVD based camera.
Try bypassing the card reader by dragging the info off of the card on to your desktop or other hard drive. Even better yet, make a disk image from the card and you can archive that as well. It seems to me the card reader is to blame.
Jeremy
Jeremy Garchow
March 3, 2008 at 3:42 pmHey Bill, I have only done this twice, but when I did it worked. I copied the whole entire contents of the card, not just the one folder. I made a new folder, then dragged the entire contents of the card into that folder. It worked great. Make sure to go into the log and transfer prefs and choose which format you want to import the movie into. I suggest ProRes over AIC.
Jeremy
Jeremy Garchow
March 4, 2008 at 4:54 amNo worries. The log and transfer preferences are at the top right of the log and transfer window in a drop down menu that looks like a gear.
If that doesn’t work, let me know.
Jeremy
