Activity Forums Adobe Premiere Pro AVCHD Export format problem
  • AVCHD Export format problem
    Posted by James T’seleie on August 2, 2013 at 2:00 am
    Hi again folks,
    I record footage in 1080p 60fps AVCHD. When I export to a predefined format (such as youtube widscreen HD) in premiere pro my output file has some weird behaviour, it looks worse than the source footage and has what almost looks like some kind of jitter. It’s most apparent when the camera is panning, but that is fairly frequent so it gets really annoying. What is the ideal output format to use to maintain video quality with 1080p 60fps MTS files? As always, your advice is greatly appreciated!
    Take care,
    James
    James T’seleie replied 13 years, 1 month ago 2 Members · 2 Replies
  • Angelo Lorenzo
    August 2, 2013 at 4:49 am
    [James T'seleie] “What is the ideal output format to use to maintain video quality with 1080p 60fps MTS files?”
    The question is moot unless we know what you’re trying to deliver to. I assume, based on your preset, websites like YouTube.
    Presets are just that, I would treat them as a base for your export that may need some customization.
    I would also assume you’re using the 29.97fps export which may lead to the jitter you feel in your pans. Solution: Select frame blending during export or match your export framerate to your project, in this case 59.94.
    Bitrate usually needs to be increased to account for another round of conversion by YouTube and Vimeo. I usually like to increase the preset values by 50%, in your case if you stick with 59.94 you may need to increase your bitrate by 150-200%. I also like setting the keyframe value to half that of the frame rate. I feel like these adjustments cater to more real-world exports; the presets are VERY conservative.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • James T’seleie
    August 2, 2013 at 4:41 pm
    Thank you kindly! I will experiment with some export settings for YouTube. I’ve tested it using some higher quality presets and the video looks great, it just the YouTube preset which really destroys everything.
    Again, can’t thank you enough for the response!
    Take care,
    James
