Activity › Forums › VEGAS Pro › AVCHD and Proxy
  • AVCHD and Proxy
    Posted by Jeff Mcguire on September 28, 2009 at 11:27 am
    I use the UpShift program to create proxy files for Vegas Pro 8.1
    I am new to this process. Should I somehow switch back to the orginal files before final rendering? Is there much of a quality loss just using the proxy?
    Jeff
    Jeff Mcguire replied 17 years ago 2 Members · 2 Replies
  • John Rofrano
    September 28, 2009 at 2:28 pm
    UpShift should probably not be used to make proxies because it has no way to switch back. You should use UpShift to make full quality HDV substitutes for your AVCHD files and then work with those.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jeff Mcguire
    September 28, 2009 at 7:32 pm
    Thanks for your reply. I was just curious. The rendered files look great with UpShift as is.
    Jeff
