Activity Forums Adobe Premiere Pro AVCHD and AVI Multicam
  • AVCHD and AVI Multicam
    Posted by Jeremy Phillips on August 13, 2009 at 10:38 pm
    I regularly film events for schools and local groups, including drama productions and concerts etc… I normally use 4 cameras, 3 of which are Sony MiniDV camcorders and the other is a Sony HDR-SR12 AVCHD HDD Camcorder.
    I use Premiere Pro CS3 to edit these together. I have only just recently started using the Sony HD camera and I still haven’t found the best way to edit this with my other DV cameras. They work very well capturing, adding to timeline then using premiere’s multicam tool to edit together. I have tried with the sony utility that comes with the camera, converting to an mpeg2 file and using that in premiere which works but i know it is not the best way.
    Does anyone have any similar experiences or know of the best way I can edit all of these together.
    Any help would be most appreciated
    Jeremy
    PC Spec
    Intel Core 2 Quad Q8400 2.66GHz
    4GB DDRII 800
    ASRock N7AD-SLI
    Gigabyte NVidia 9500GT 512mb
    2x HP L2045w DVI Monitors
    M-Audio Delta 66 Sound Card
    Jeremy Phillips replied 17 years, 1 month ago 2 Members · 2 Replies
  • Jon Barrie
    August 14, 2009 at 12:47 am
    Convert the AVCHD file into a DV file so all your clips are natively DV. This will keep the system less stressed during the multi-cam edit process.
    – JB
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Jeremy Phillips
    August 14, 2009 at 7:58 pm
    Yes I thought about that and that would seem the best way for the pc. How would you recommend I do this? I have access to Sony Vegas 9 which I know handles native AVCHD but what settings would be best to export this to AVI.
    Jeremy
    PC Spec
    4GB DDRII 800
    ASRock N7AD-SLI
