Activity › Forums › Apple Final Cut Pro Legacy › avchd
Posted by Phil Hall on August 28, 2010 at 9:42 am
Hi Could anyone working with AVCHD offer any advice. I have just started using FCP 7 and recently purchased a panasonic ag hmc 152 camera. I can Log and capture and edit without any issues. I use the prores 422 as my capture and sequence settings, burning to a blu ray disc looks awesome. However making a dvd looks really really bad. My footage has jagged blocks on the edges and I would be red faced to show anyone. as I mentioned before the bluray looks great but as we all know some clients like dvd still. Any advice awould be greatly appreciated.
Phil
Phil Hall replied 16 years ago 5 Members · 8 Replies -
Chris Tompkins
August 28, 2010 at 12:39 pmYou didn’t list your step taken to create a SD DVD…
Chris Tompkins
Video Atlanta -
Gary Adcock
August 28, 2010 at 1:52 pm[Chris Tompkins] “You didn’t list your step taken to create a SD DVD…”
Nor did he mention if he was monitoring that SD footage on an SD TV?
trying to match the BR on the same display would be BAD.very bad.gary adcock
Studio37Post and Production Workflow Consultant
Production and Post Stereographer
Chicago, ILhttps://blogs.creativecow.net/24640
John Fishback
August 28, 2010 at 7:30 pmIf you search “sd from hd” you should see lots of suggestions how to do what you want.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Phil Hall
August 29, 2010 at 8:01 amHi Chris
I have done the following. From the FCP menu > Share > Create DVD
I have also Export as QT movie current settings then imported in to compressor then in to DVD Studio.
I have also Export as QT Movie and changed it to a H.264 then in to compressor then DVD Studio
(which looked the best out all of them) but took about 8 hours for a 30 minute dvd. I have also done send to compressor with the worst results. What am I doing wrong?Phil
Phil Hall
August 29, 2010 at 8:10 amHi Gary
I Played the footage from a dvd player on a Panasonic plasma, I played the dvd on to CRT monitor and a LCD portable DVD player. The footage looks bad no matter what I use. The same footage on Edius 5 to DVD looks ok. It’s only from FCP I have a problem and I would say I’m doing something wrong for it to look so bad. Even in the preview in compressor looks really bad.
Michael Gissing
August 29, 2010 at 11:12 amIf making an h264 then going into DVDSP looked better, then clearly you are doing something wrong. You do know that DVD needs mpeg2 from Compressor and that Compressor has very good presets to make m2v files from a quicktime.I suspect you are going through a horrible and unnecessary transcoding.
If you are exporting a quicktime using current settings and your timeline is correctly setup, then you should be able to make a decent DVD. But what we need to know is the details of the codecs used in the various steps.
You mention ProRes for the camera originals. What are the sequence settings, and the settings used in Compressor.
Phil Hall
August 29, 2010 at 11:37 amHi Michael
For my capture settings in log and transfer AVCHD plug in is set to ProRes 422
for my sequence Apple pro res 422 1440 X 1080 50i 48 khzWhen I insert a clip in the time line FCP change sequence to match clip settings?
I tried yes and No with the same resultsin compressor I’m using the dvd mpeg2 best quality 90 mins and leave it as is I don’t play around with the settings.
I’M sure your write I doing something wrong but I searched just about everywhere it find out what
Phil Hall
August 30, 2010 at 3:02 amMay Be I should ask what should my Sequence settings be in FCP 7 for AVCHD?
