Activity Forums Adobe Premiere Pro AVCHD 1080 60p settings in premier pro cs 5
  • AVCHD 1080 60p settings in premier pro cs 5
    Posted by Chris Mclaughlin on January 9, 2012 at 10:01 pm
    Hi
    What project settings should I use in premiere pro CS 5 if I have 1080 60p footage. From what I understand premiere pro can import these AVCHD files at 60p but I only see settings for 1080p 30p. The footage was shot using a panasonic tm-900 and from what I understand only shoots in 1080/60p/60i….Does premiere pro automatically make the footage 60i or possibly 30p or will it be true 1080 60p. If I shot in 1080 60i and used a 1080p 30p setting would that work better? Is 1080 30p the same as 1080 60i? Or is it just easier to use software to convert the AVCHD files to .mov. I really dont want to do that if possible. Extra step in the workflow.
    I am running snow leopard on a 3.06 core duo macbook pro.
    8 gig ram
    7200 rpm HDD
    adobe masters suite CS5
    John Frey replied 14 years, 8 months ago 3 Members · 3 Replies
  • Ann Bens
    January 9, 2012 at 10:22 pm
    Use a setting that matches the footage.
    Either drag the clip into the New Item icon or
    make a custum sequence setting.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Chris Mclaughlin
    January 9, 2012 at 10:35 pm
    hi Anne thanks for your help…so it wont be a problem because I have read that AVCHD in 1080/60p has a higher bit rate then say a standard AVCHD file and I have read that mac applications will not read it because it is not a standard format. ..has that changed in CS 5?
    thanks for your help as I am kinda new to this.
  • John Frey
    January 10, 2012 at 7:06 pm
    We have a couple of TM700s and always shoot in 1080 60p. If you follow the earlier suggestion and let Premiere interpret footage, you will get a yellow bar and everything looks and plays fine. I am currently using CS5.
    John D. Frey
    25 Year owner/operator of two California-based production studios.
    Digital West Video Productions of San Luis Obispo and Inland Images of Lake Elsinore
