Activity Forums VEGAS Pro AVC MP4 files captured from Blackberry Playbook won’t open in Vegas?
  • AVC MP4 files captured from Blackberry Playbook won’t open in Vegas?
    Posted by Ric Thot on May 26, 2012 at 12:40 pm
    Hi guys,
    I’m kind of new to all this and tried to find some info in google without success. I have a bunch of video files captured from a Blackberry playbook. I’m trying to add those files in Vegas Pro 11 for some editing but it seems Vegas is unable to preview the file – I can’t do anything with it in Vegas.
    Media info gives me the following info for those files:
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 11mn 8s
    Source duration : 11mn 8s
    Bit rate mode : Variable
    Bit rate : 5 572 Kbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Stream size : 444 MiB (98%)
    Source stream size : 444 MiB (98%)
    Language : English
    Encoded date : UTC 2012-05-26 00:41:42
    Tagged date : UTC 2012-05-26 00:41:42
    mdhd_Duration : 668223
    container: mp4
    Not sure exactly what is the problem, I’ve been able to edit AVC files in Vegas from other sources before, do you guys see anything in the above info that isn’t supported by Vegas Pro?
    Jack Robins replied 13 years, 7 months ago 4 Members · 3 Replies
  • Mike Kujbida
    May 28, 2012 at 11:12 am
    Odds are that Blackberry uses a customized version of the codec for their Playbook.
    Can you post a small clip to a site such as Dropbox for us to experiment with?
    Using https://db.tt/rYE74u2 will get both of us an extra 500 MB. over and above the free 2 GB. limit.
  • Eric Santiago
    July 12, 2012 at 11:53 am
    Scouring the Cow for same answers but using FCPX.
    Weird thing is that FCPX will show it in the Import window but will not let it ingest.
    I had to run MPEG Streamclip and convert to QT h.264.
    Files are huge but as soon as I get an optimized version in FCPX, Im toasting the originals.
  • Jack Robins
    January 20, 2013 at 9:37 pm
    I ran into this issue with Vegas 11.
    Solution? Downgraded back to Vegas 9.
    The way Vegas 10 & 11 handle MP4’s are different then Vegas 9
    I event tried different version of QuickTime to be sure.
    The Playbook shoots great HD Video for a device that is so inexpensive.
