Activity Forums Blackmagic Design AVC-Intra Support
  • AVC-Intra Support
    Posted by Gian Martins on February 21, 2010 at 4:12 am
    We’ve recently acquired a Panasonic P2HD HPX300 camera and we’re having problems while editing with AVC-Intra coded.
    We have a BlackMagic Design Multibridge Pro installed on a 4GB Quad Core system running a 64bit Windows OS.
    When we build a project without BlackMagic, Premier reads the codec perfectly and we can even playback without the need of rendering.
    But when we run BlackMagic for TV output, it doesn’t work even if the project is rendered. Right after pressing Play, the movie stops.
    Is there anyone here who had similar problems and knows any solution?
    Thank you.
    Gian Martins replied 16 years, 6 months ago 2 Members · 2 Replies
  • Vince Becquiot
    February 21, 2010 at 5:13 pm
    I’m not sure what the support status is for Blackmagic in AVC-Intra.
    What are they saying?
    The issue we did run into was with 30PN (if that’s what you are shooting). We resorted to previewing through DVI as an extended display since neither the Blackmagic or AJA card could play it back correctly.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Gian Martins
    February 23, 2010 at 2:52 pm
    I have founded a solution.
    Only upgrade premiere pro for 4.2.1 and instal a newest codec.
    thank you.
