AVC-Intra Spanned Clip Error
hi,
i received footage from an HPX-2700, recording in 720pn25 ACV-I codec. the material is VFR at 50fps and is solely on one card. when i mounted the card via a PCD-20 card reader in P2CMS they were 9 clips. of the 9 clips they were 7 that appeared with exclamation icons indicating they are spanned and have not ‘found’ their ‘partners’. upon closer inspection these clips are all identical in size, 4GB, follow each other in timecode and are frame accurate. what may have caused this strange behavior? the camera was used for aerial shots and was attached to the outside of a helicopter and recording was initiated immediately during take-off and left rolling until card full.
any insight? thanks,
pasquale
