Activity Forums VEGAS Pro AV Sync problem-Pro advice desperately needed
  • AV Sync problem-Pro advice desperately needed
    Posted by Richard Diandrea ii on January 4, 2010 at 1:54 am
    I am a novice and have worked hard at learning to work with vegas and video files in general. I really enjoy this as a hobby…working with home video. I believe in the minimalist approach…appreciating subtle editing…alowing the subject be thae main focus of attention. I find the real art is taking the half decent video (at best) that I shoot and turning it into something entertaining for the family to watch and re-experience. i do’t want to get in the way. Only enhance.
    The point is I don’t try to do anything really crazy and thats why I am so damned frustrated at some of the issues i have had. The most recent and most difficult to find a reason or solution for is what appears to be a sync problem. I just edited a recent trip using Vegas 9c. The file itself is about 45 minutes long. I just tried watching it on my Popcorn Hour (200c). About 6:30 into the video it all of a sudden went out of sync. The video looked as though it was stuttering slightly. Audio was fine…the video is off abit.
    I thought that I may have messed up the edit. I opened the Veg file and began to play the video. It begain doing it at about the same spot. However, after repeated tests, it does NOT do it consistantly at the exact same spot. It is as though after a certain amount of time it just can’t keep up any more and it starts messing up. It does it at many places after a while of,playing but never at the exact same spot.
    What is weird is that I played another file that I rendered…I believe in the exact same way I rendered the problem file, and it played for about 10-15 minutes with no problems at all.
    I have serached for similkar issues…I found a couple that seem similar but i didn’t understand much of the termonology that was used so i don’t know if it was the same or not. What am I missing here? Is there something i can do to prevent this??
    The machine I’m using is a Vaio VGN AW190, Duo Core 2.8 GHz, 8 GB RAM, 64bit OS.
    ANY help will be great;ly appreciated.
    JR
    John Rofrano replied 16 years, 8 months ago 2 Members · 12 Replies
  • 12 Replies
  • John Rofrano
    January 4, 2010 at 1:20 pm
    What format are the files that you are editing? What format and bit-rate are you rendering to? Without this info it’s tough to say what might be going on.
    Try making a RAM preview (i.e., make a timeline selection and press Shift+B) and see if it still stutters. It should not. If it does stutter then you need to determine what is it about that part of the project that might cause the problem. It could even be a corrupt source file.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Richard Diandrea ii
    January 4, 2010 at 5:09 pm
    Hi JR. Thx for responding.
    Of course…that info would be helpful to you!
    The original files are AVCHD shot on a SONY HDR SR1. Frame rate is 29.79. The projct property settings;
    Pixel Format: 32-bit floating point(Full Range)
    Full resolution rendering quality: Best
    Adjust source media to better match project or render settings: This is checked
    AUDIO
    Sample Rate: 44KHz
    Bit Depth: 16
    Resample & strecth quality: Best
    Stereo
    Rendered Using SONY AVC
    Template: AVCHD 1440×1080-60i
    I can’t think of anything else at the moment.
    Thanks.
    Richard
  • John Rofrano
    January 4, 2010 at 5:31 pm
    Try turning off 32 bit floating point. Audio for video should be 48K (not 44K). Did you try Shift+B? What did you see?
    ~jr
    January 4, 2010 at 6:00 pm
    I’m not sure I’m doing this correctly…I opened the VEG file and highlighted a section of the video. Then I simply pressed “Shift” & “B” at the same time…then pressed play. Is this correct? It did dtill stutter and go off sync.
  • John Rofrano
    January 4, 2010 at 7:01 pm
    Yea, that’s correct. Did turning off 32-bit pixel format help?
    ~jr
    January 4, 2010 at 7:12 pm
    It seemed to flow well fo about 7 minutes. then all of a sudden it began doing it again. It is strange how the video looks when it begins doing it. All of a sudden the video will start slightly hesitating. I don’t know how else to explain it. It’s as if it just can’t keep up any longer…..
  • John Rofrano
    January 4, 2010 at 7:19 pm
    Yea, it’s really strange which is why I asked about doing a RAM preview because that would eliminate your CPU from the equation. AVCHD is really hard on a CPU but this is really strange behavior if it runs for 7 minutes without problems and they stutters. Is it only with this project or do other projects have this problem too?
    ~jr
    January 4, 2010 at 7:31 pm
    Others, too. But not all. It happens when I play the renedered file and the veg file. But almost never in the exact same spot….near the same place just not exactly. It also does it when playing via my “Popcorn Hour” digital Media player thru my projector. Really driving me crazy!!
    You know, this also happened with an old file I was editing that was originally shot on my old Hi-8mm camcorder. I have to start looking at everytthing to see if all my stuff is buged.
    January 6, 2010 at 6:38 pm
    John…hope you’re still out there listening! Or, of course, anyone else that may help me figure this out.
    What I’ve done since my last post was to experiment a little. Again, I am not very literate with hardware or software so the likely hood of me doing something wrong is high. Anyway….I have repeatedly played the veg file and the rendered digital file of the same video with the following settings;
    Pixel Format: 8-bit
    AUDIO
    Sample Rate: 48KHz
    Bit Depth: 16
    Stereo
    Everytime I play either file back thru Vegas 9 (veg file) or indows media (AVC rendered file) it will eventually go out of sync. NEVER in the exact same spot. Some tmes it is in the same area…some times it is not. It isn’t like there is an obvious GLITCH or scratch that creates a [problem at the exact spot each time. It always varies. This tells me the chances of it being related to my hardware is significant.
    The other machine I’m uing to play my digital files is a Popcorn Hour C-200. I get the same type of results using both machines.
    To try & identify if it’s a hardware issue, I used Vegas to render and burn to Bluray disc.
    Playing the disc back on my Vaio Notebook…it played perfectly. NO SYNC issues!!! Do you believe it’s a hardware issue?? How can I be sure?? More importantly….How the hell can i play these great files in the best quality withour down sizing its resolution??!!!
    Thank you.
    Richard
  • John Rofrano
    January 6, 2010 at 7:48 pm
    The fact that the Blu-ray version plays correctly says that it’s not Vegas or the render… it’s the playback device. Try using a different media player on the PC. What is really odd is that the Popcorn Hour has the same problem. Maybe it’s the bit-rate is too high? The default bit-rate for Sony AVC | AVCHD 1440×1080-60i is 15,000,000. Try knocking it down to 9,000,000 and see if that helps any.
    I have a WD TV HD Media Player and I use 9MBps AVCHD files with that and they play back fine. Worth a try.
    ~jr
