Activity Forums Apple Final Cut Pro Legacy A/V setting issues/ Edit to tape from FCP to Sony digital HDV deck
  • A/V setting issues/ Edit to tape from FCP to Sony digital HDV deck
    Posted by Ben Swicegood on February 17, 2011 at 6:23 pm
    Hey i’m trying to export/edit to tape from FCP to a Sony HDV deck (GV-HD700/1) using a firewire cable. Does anybody know what settings I should be using to write onto the deck? I have a show that needs to go to CBS, and they prefer HDV mini tapes.My sequence was captured in 1080i60. They want it in 720×480. Not able to get the sequence onto tape. Help!
    I am new to all this and really need some advise. I been trying every which way and need your help.
    Andrew Rendell replied 15 years, 6 months ago 2 Members · 1 Reply
  • Andrew Rendell
    February 18, 2011 at 2:33 pm
    I’m not familiar with that deck, but I’ve had a look at the specs and there’s a couple of things to watch out for:
    The deck appears to only record SD and not HDV, but that’s ok as 720 x 480 is SD. So from the FCP I’d export a SD 720 x 480 version of your cut and bring it back into FCP as a single file and play that out to the deck. You probably need to manually record a bit of black at the start of the new tape in order to assemble the new recording onto it.
