Activity Forums Apple Final Cut Pro Legacy Autosave Disconnecting Media
  • Autosave Disconnecting Media
    Posted by Max Frank on July 25, 2011 at 11:36 am
    Whenever I open an Autosaved project, the media appears disconnected – even though the same
    drives are connected and the media is in fact available.
    Any idea why that’s happening and what I can do to correct it?
    Tx,
    W
    Latest FCP7 & OS X 6
    Jerry Hofmann replied 15 years, 2 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    July 25, 2011 at 10:12 pm
    I guess I’m lucky or something, bur rarely need to open autosaves… that said, they always remained connected to the media unless I’ve moved it of course. If you didn’t do that, then it should reconnect automatically or with a simple reconnect media command. Does it reconnect OK?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
