Activity Forums Apple Final Cut Pro Legacy Automating Slate Creation
  • Automating Slate Creation
    Posted by Mike Green on April 24, 2013 at 6:41 pm
    Hello Everyone,
    Long time reader, first time caller…
    I have to create approximately 300 slates of 10 seconds each. The slates are nothing fancy, white type on black background and the only thing unique is a ID number.
    This ID number will probably be from an excel spreadsheet.
    I’m just trying to figure out a way to automate this.
    Thank you in advance for any suggestions.
    Mike Green replied 13 years, 4 months ago 2 Members · 2 Replies
  • John Heagy
    April 26, 2013 at 1:32 pm
    If you manually create a timeline with 300 identical slates spaced out as you need you can export that as XML. Via some find and replace trickery you can modify each slates info in the XML and import that back into FCP.
  • Mike Green
    April 30, 2013 at 8:21 pm
    Thank you for your response! I’ll give it a try.
