Activity Forums Apple Final Cut Pro Legacy Automating repetitive tasks
  • Automating repetitive tasks
    Posted by Rob Macaulay on November 17, 2009 at 3:30 pm
    I am looking to automate a task in Final Cut Pro, such as adding 15 frames at the beginning and ending of a asset and adding intro in and intro out on an asset.
    I’ve read where one guy has used automator to create a scrip, or macro to automate final cut pro actions sucessfully.
    Can anyone give advice on how best to automate tasks in final cut pro?
    Nick Meyers replied 16 years, 10 months ago 3 Members · 3 Replies
  • Arnie Schlissel
    November 18, 2009 at 3:28 am
    Check out Traffic from xmedit.com.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Rob Macaulay
    November 18, 2009 at 9:43 pm
    Thanks a bunch Arnie,
    This looks to be an awsome utility. Looks very much like the middleware I use.
    Have you used Traffic? I’m definately checking this out and the price is great, too!
  • Nick Meyers
    November 19, 2009 at 6:35 am
    i use QuicKeys, and its pretty effective if you have a huge amount of repetitive tasks.
    it’s about $80-90 but there other apps that do essentially the same thing for less $$
    it does take a certain amount of time to program the macros,
    so it;s only really effective if you need to do the same thing a lot of times.
    although what you need sounds pretty simple to program.
    an important trick when programming macros is the PAUSES you leave between certain commands.
    nick
