Activity › Forums › Adobe After Effects › automating manual frame adjustment, please?
  • automating manual frame adjustment, please?
    Posted by Ania Leszczynska on November 5, 2020 at 3:24 pm
    I have a video file that is animation, so it uses different frame rate throughout: althouth the movie is on fixed 25fps, the actual images are animate on a mix of 1s, 2s and 3s.
    Is there a way AF could analise the video and apply the same mixed framerate on the effect put on top of the video?
    Kind of like time-remapping the effect animation layer with Toggle Hold Keyframes, so when the base video switches to 2s (12.5fbs) the frame of the effect animation is held for two frames, but then goes back to 1s (25fps) when the base animation does.
    The only way I could come up with was actually time-remapping the effect, but that is insanly time consuming checking each and every frame to match up, so wondering if anyone’s got a suggestion?
    Andy Kiernan replied 5 years, 10 months ago 2 Members · 1 Reply
  • Andy Kiernan
    November 6, 2020 at 1:46 pm
    I dont think there is an automagic way to do this, perhaps using the posterize time effect and key framing that would be easier than using time remapping.
