Activity Forums Adobe After Effects Expressions Automating Importing photos and pairing to sequences
  • Automating Importing photos and pairing to sequences
    Posted by Jeremy Clevenger on January 17, 2024 at 3:44 pm
    I am in the process of writing another script to automate my tedious workflow. I essentially have 2500 photos that need to be paired to sequences in the project that have similar names. They’re all broken into subfolders in the project and in the photos original location on the OS. The photos are named lastname_firstname and in my project the sequences are all named 00#Firstname Lastname for extended expression reasons. At this stage, I have the script seemingly recognizing matches and ready to import, but I am getting stuck on the importing to the original sequence stage. Any help is appreciated. Full disclosure, I was unfamiliar with the Levenshtein algorithm so I used ChatGPT to help generate this script, so there may very well be errors I am overlooking because of that.
    // Function to calculate Levenshtein distance between two strings
    function levenshteinDistance(a, b) {
    if (a.length === 0) return b.length;
    if (b.length === 0) return a.length;
    var matrix = [];
    // Initialize matrix
    for (var i = 0; i <= b.length; i++) {
    matrix[i] = [i];
    for (var j = 0; j <= a.length; j++) {
    matrix[0][j] = j;
    // Calculate Levenshtein distance
    for (var i = 1; i <= b.length; i++) {
    for (var j = 1; j <= a.length; j++) {
    if (b.charAt(i – 1) === a.charAt(j – 1)) {
    matrix[i][j] = matrix[i – 1][j – 1];
    } else {
    matrix[i][j] = Math.min(
    matrix[i – 1][j – 1] + 1,
    matrix[i][j – 1] + 1,
    matrix[i – 1][j] + 1
    return matrix[b.length][a.length];
    // Function to resize the footage layer to comp width
    function resizeFootageToCompWidth(footageLayer, compWidth) {
    var sourceRect = footageLayer.sourceRectAtTime(0, false);
    var scaleFactor = compWidth / sourceRect.width;
    footageLayer.scale.setValue([scaleFactor * 100, scaleFactor * 100]);
    // Selecting the active folder in the project to search
    var project = app.project;
    var folder = project.activeItem;
    var sequences = folder.items;
    // Create an associative array to pair sequences with compositions
    var sequenceComps = {};
    // Prompt the user to select the photo folder
    var footageFolder = Folder().selectDlg(“Select the footage folder”);
    if (!footageFolder) {
    alert(“No folder selected. Script aborted.”);
    } else {
    // Get a list of files in the selected footage folder
    var footageFiles = footageFolder.getFiles();
    // Set a threshold for similarity
    var similarityThreshold = 5; // You may need to adjust this based on your needs
    // Counter for the number of matches found
    var matchCount = 0;
    // Iterate through each file
    for (var i = 0; i < footageFiles.length; i++) {
    var fileName = footageFiles[i].name;
    // Parse the firstname and lastname from the file name
    var nameParts = fileName.split(“_”);
    var lastname = nameParts[0];
    var firstname = nameParts[1];
    // Find the closest match in sequences
    var bestMatch = null;
    var minDistance = Infinity;
    for (var j = 1; j < sequences.length; j++) {
    var sequenceName = sequences[j];
    var distance = levenshteinDistance(sequenceName, firstname + ” ” + lastname);
    if (distance < minDistance && distance <= similarityThreshold) {
    minDistance = distance;
    bestMatch = sequenceName;
    if (bestMatch !== null) {
    // Check if the file is valid
    if (footageFiles[i] instanceof File) {
    // Check if we already have a composition for the sequence
    var sequenceComp = sequenceComps[bestMatch];
    // Import the image into the composition
    var importedFootage = app.project.importFile(new ImportOptions(footageFiles[i]));
    var footageLayer = sequenceComp.layers.add(importedFootage);
    // Resize the image to comp width
    var compWidth = sequenceComp.width; // You may need to adjust this based on your comp settings
    resizeFootageToCompWidth(footageLayer, compWidth);
    // Increment the match count
    matchCount++;
    } else {
    alert(“Skipping non-image file: ” + fileName);
    // Display the number of matches and total files found
    alert(“Total files in folder: ” + footageFiles.length + “\nTotal matches found: ” + matchCount);
    Roland R. kahlenberg replied 2 years, 7 months ago 2 Members · 1 Reply
