Automaticaly seperate a long line of text to two lines
Hello Guys!
I’ve prepared some animations in the 16/9 format.
I have to prepare an option for the customer to have the possibility to use those animations in 9/16 or square format.
I do it with expressions and motion graphics templates.
It’s ok, but i have a big problem.
When the line is to long i search a solution to cut this one automaticaly and obtain two lines of text with the same text source.
But the big difficulty is that all has to be automatic.
I need after effects to find where is the nearest “space” from twe two last words of the line and automatically cut the line in two.
Do you know if there is a solution for that or it’s impossible?
Thanks a lot
Loïc
