Activity Forums Adobe Premiere Pro Automatically cut (slice) video footage into many clips
  • Automatically cut (slice) video footage into many clips
    Posted by Joseph Freeman iii on February 1, 2018 at 8:03 pm
    I have been asked what appears to be a simple question, but I can’t determine a simple solution.
    How to “automatically” cut video footage into many clips based upon an user time interval.
    Import a clip of “any length”, then do what ever procedure necessary to “automatically create many separate clips based upon the user’s time value.”
    Example(s):
    If you import a 10 second piece of footage and want each clip to be 1 second, then 10 separate clips would be produced.
    OR
    each clip is to be x number of frames then there would be “(total running time x Frames per second) / number of frames per clip” number of clips. Last clip may be shorter due to the result not being an interval.
    Thank you in advance.
    Joseph Freeman
    Joseph Freeman iii replied 8 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
