Activity › Forums › Adobe Premiere Pro › Automatic Transition
  • Automatic Transition
    Posted by Ben Oliver on August 15, 2017 at 5:14 pm
    when i use the shortcut, APPLE – T to apply a basic dissolve/audio fade on a cut, it automatically puts a dissolve/fade on the beginning and ending of the clip….not just on the cut I’ve selected.
    Is there anyway to turn this off? So that the transition is only applied at the point where I want it to?
    John Heiser replied 9 years, 1 month ago 2 Members · 1 Reply
  • John Heiser
    August 15, 2017 at 8:19 pm
    Which version of Premiere are you using? The default shortcut for adding a dissolve is CMD+D. Also, make sure you have actually selected the cut or the end of the clip, rather than the entire clip.
