Activity › Forums › Adobe After Effects Expressions › automatic renumber of expression on duplicate?
  • automatic renumber of expression on duplicate?
    Posted by Andy Engelkemier on August 8, 2013 at 11:55 am
    This is a basic one, but I’m not sure of an answer.
    When you duplicate several layers at once with Ctrl+D, or just copying and pasting them, the expression stays the same, but the layer name changes.
    So I might have something basic like: thisComp.layer(“roll 2”).transform.position
    If I duplicate that along with the layer “roll 2” the layer will now be called “roll 3” but the expression stays as “roll 2” I can see how many times this would be desired.
    Is there an alternate way of duplicating that would automatically change those?
    Andy Engelkemier replied 13 years, 1 month ago 2 Members · 2 Replies
  • Annebelle Van zweden
    August 14, 2013 at 1:17 pm
    thisComp.layer(thisLayer, +1).transform.position
    The +1 means ‘one layer below’
  • Andy Engelkemier
    August 14, 2013 at 1:21 pm
    Oh, that totally works. I just have to keep an eye on accidentally reordering things. I manually did that on the previous project, but I’ll have to do something similar on my current one, so I can use that for sure.
    Thanks Annebelle
