Activity Forums VEGAS Pro Automatic & random transition effects in the slide show(VMS Platinum HD 10)
  • Automatic & random transition effects in the slide show(VMS Platinum HD 10)
    Posted by Trung Dao on December 14, 2010 at 3:36 am
    Hello Expert(s),
    Does any one know how to insert the AUTO & RANDOM TRANSITION EFFECTS ON TO THE SLIDE SHOW(VMS HD PLATINUM 10)? I just got my VMS-HD10 a month ago and while playing with it I got it to do it but I couldn’t remember how to do it again…I know how to insert it in one by one but not the AUTO/RANDOM. Please help!!
    THANK YOU!!
    JAVA
    Trung Dao replied 15 years, 9 months ago 3 Members · 3 Replies
  • Edward Troxel
    December 14, 2010 at 3:30 pm
    Upgrade to Vegas Pro and use a script?
    Edward Troxel
    JETDV Scripts
  • Dale Mcclelland
    December 14, 2010 at 6:03 pm
    When you initially create a slideshow using Insert/Slideshow, there are two tabs in the resulting dialog. The dialog opens to the default tab that allows you to add pictures. The other tab is named “Settings” and allows you to select transitions.
    I am not sure how/if you can change the transitions to random for a slideshow that has already been created.
  • Trung Dao
    December 15, 2010 at 4:33 am
    Thank you! You are right. Now I remembered how to do it now. JAVA
