Activity Forums Adobe After Effects Automatic Mask Creation on Still Image?
  • Automatic Mask Creation on Still Image?
    Posted by Jay Blanchard on August 31, 2005 at 2:18 pm
    Does anyone know if there is anyway (either in AE or with a plug-in) to automatically create a mask around a cropped still photo? Here’s my example–I cropped my image in Photoshop (used pen tool, made selection, deleted background, etc.) then brought it into AE 6.5. Now I would like to render an animated stroke along the image’s outer edges.
    Does the .psd file carry my original work path in anyway? If not, is there anyway I can create the path in AE without having to retrace my image? (I need to do this for dozens of images, so it would be a huge timesaver).
    Michael Szalapski replied 21 years ago 4 Members · 4 Replies
  • Guy
    August 31, 2005 at 2:26 pm
    not sure if PS paths translate to AE automatically, however if you try using:
    Layer > Autotrace
    a mask will be created around the alpha channel of your layer.
    you can even autotrace many layers at one time.
  • Adam Bennett
    August 31, 2005 at 2:30 pm
    Save the path you have created in Photoshop as a work path, then go file > export > paths to illustrator.
    Open the illustrator file you now have and then simply copy and paste the mask onto your image. You might need to shift it around a bit and adjust expansion and handles, but it should be the same size
  • Jay Blanchard
    August 31, 2005 at 2:59 pm
    Excellent advice–thanks for quick help!
  • Michael Szalapski
    September 3, 2005 at 8:28 am
    Just a note in case it helps:
    If you want a rectangular (or circle) mask put around your footage simply doulbe-click on the mask tool in the tools pallette.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great)
