Activity › Forums › Avid Media Composer › Automatic Duck – FCP motion parameters not carrying over to Avid correctly
  • Automatic Duck – FCP motion parameters not carrying over to Avid correctly
    Posted by Chris Wasmer on November 26, 2010 at 7:05 pm
    Using Automatic Duck to send a sequence from FCP 7 to Avid Symphony 5.
    Original clips are QT, Pros Res HQ, 1080p, 24fps.
    They have been put into a FCP SD sequence — 24fps no field dominance,
    uncompresses-8bit, 720×486, 601 NTSC (40:27) — and edited.
    Clips have been re-positioned, re-sized and cropped to fit into SD graphic boxes with lots of graphic text.
    FCP sequence exported with Duck via AAF, create externally linked files, 24fps, 1:1.
    And Imported into Avid.
    But the clips in Avid don’t match the FCP parameters — they are way too small and not positioned the same!
    I suspect that this has something to do with the fact that the original QT clips are HD.
    Does anyone have a good workflow suggestion, so that layout in FCP will carry over to the Avid?
    I need clips in Avid to have some handles, and to be re-sized and repositioned exactly as they appear in FCP.
    THANK YOU.
    Chris Wasmer replied 15 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
