Activity › Forums › Adobe After Effects › Automatic Dedust plugin
Posted by Stephane Fournier on February 9, 2006 at 4:56 pmHello,
I’m doing more and more work on film sources and
find myself spending too much time taking out scratches
and hairs manually.Is there a plugin that could do this (or some of this) for me ?
Thanks !
Stephane Fournier replied 20 years, 7 months ago 4 Members · 7 Replies -
Chris Smith
February 9, 2006 at 5:40 pmThere is the built in (6.5 and 7.0) CC Simple Wire Removal effect which should do nicely for scratches and some marks.
Chris Smith
https://www.sugarfilmproduction.com -
Stephane Fournier
February 9, 2006 at 6:12 pmYeah, but that’s not an automated plugin from what I know, is it ?
Thanks !
Chris Smith
February 9, 2006 at 6:22 pmI could be wrong, but it’s about as automated as any technique may get. There are noise reducers that may help with dust and noise here and there that change between frames. There is a clone that can clone from other frames for fixing one frame scratches. But none of this is “Automatic”. There will always be some kind of tweaking somewhere. There’s the median filter, but you will need to do some masking or keying to isolate certain areas so the whole image doesn’t look like art.
I do a technique where I use a keyer to grab skin, Duplicate this layer, use median on it then if the blemish or unwanted thing is darker than the skin set the transfer mode to lighten. So that whereever your ugly spot is, it’s replaced by a smeared version of the area around it.
Many techniques, but there is always some kind of work involved.
Chris Smith
Stephane Fournier
February 9, 2006 at 6:28 pmYeah, sounds like what we do here.
Well, that’s it then, I’m gonna have to hire a monkey !
Craig
February 9, 2006 at 10:01 pmOne way to do it would be to output your comp to frames, then do an automated batch in photoshop that applies the “dust and scratches” effect. You can make it save to a different folder, then reimport the footage as a frame sequence and reoutput to whatever format you desire.
good luck!
-c
Andrew Yoole
February 10, 2006 at 3:27 am -
Stephane Fournier
February 10, 2006 at 5:48 pmThat’s exactly what we need, but you’re right on the price !
ouch
