Activity › Forums › DaVinci Resolve › Automatic adjustments to clips from same take? Can i turn this off?
  • Automatic adjustments to clips from same take? Can i turn this off?
    Posted by Neil Goodman on September 14, 2012 at 2:16 am
    I imported an AAF from Media Composer.
    Alot of the clips were subclipped out from the same takes so when I go to color page and start to do a primary on the first clip, the rest of the clips on the timeline from that take are changing too. Can i turn this behavior off?
    Neil Goodman: Editor of New Media Production – NBC/Universal
    Neil Goodman replied 14 years ago 5 Members · 6 Replies
  • Joseph Owens
    September 14, 2012 at 2:41 am
    [Neil Goodman] “. Can i turn this behavior off?”
    Yes its an “unlink” behaviour, or create local/remote versions.
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Neil Goodman
    September 14, 2012 at 4:01 am
    Pardon my ignorance, finally coming over from Color..where is this option to unlink? I odnt see it in a menu or anything.
    I see how to make a version 2 for each clip individually which seems to do the trick but is there a way i can do that for every clip on the timeline at once?
    Also will this technique of making new versions, effect my ability to re-link in media composer later for finishing?
  • Pepijn Klijs
    September 14, 2012 at 5:58 am
    The option is still there, but I just found out that they’ve changed the name… Couldnt find it either!
    Anyway, it’s still under the menu when you rightclick a thumbnail in the timeline and it’s called: use local grades. But this will delete any grades you might have done. ‘copy remote grades to local’ will keep the grades but break the linking.
    Good luck
    Pepo
    Editor/Colorist, Amsterdam, The Netherlands
    http://www.pepijnklijs.nl
  • Christopher Adams
    September 14, 2012 at 10:01 am
    Haha I was showing someone that same problem yesterday and could not find it either…thanks!
  • Chris Martin
    September 14, 2012 at 3:27 pm
    Using versions is a bit more house keeping but gives you way more options within a grading session.
  • Neil Goodman
    September 14, 2012 at 4:02 pm
    great, thanks everyone!
    so messing with all these versions wont efect my ability to go back to avid ?
