Activity Forums Adobe Premiere Pro Automate order clips on TL by timestamp, filename, start timecode
  • Automate order clips on TL by timestamp, filename, start timecode
    Posted by Andrew Luck on November 2, 2018 at 10:47 am
    Hello!
    Do someone know way for Premiere Pro 2018 automate to put drone clips without audio on TL by timestamp, filename, start timecode (like in old FCP7). The most interesting point do it only with timestamp, because in other causes I foresee problems with rename plugins, scripts e.t.c.
    Thank you, for help!
    John Heiser replied 7 years, 10 months ago 2 Members · 1 Reply
  • John Heiser
    November 6, 2018 at 3:05 pm
    Can’t you just sort the bin, multi-select the clips and drag them all to a timeline?
    John Heiser
    Senior Editor
    o2 ideas
    Birmingham
