Activity Forums Apple Final Cut Pro Legacy Automate fades?
  • John Fishback
    March 16, 2010 at 10:19 pm
    You can try pasting attributes using levels. Make an audio edit the way you want it, copy it, then paste attributes-levels. The only problem is you’ll still have to adjust the nodes for timing. But, it might save a little time.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
