Activity Forums Adobe Photoshop automate batch
  • automate batch
    Posted by Larry Watts on May 27, 2007 at 2:08 am
    Why cannot get the “automate”-“batch” utility in PS?
    I’m a video editor and pretty savvy computer user.
    It seems so non-intuitive, and when I go to help, I’m always lost.
    I really need to batch process some files. Here is what I want to do:
    Open a folder of tiff files, rotate each file horizontally, apply a dust filter, save it as a jpeg with the same name in the same folder. Not too hard!
    How do I do this?
    Larry
    I used to do this all the time with debabelizer.
    Adolf Witzeling replied 19 years, 4 months ago 3 Members · 2 Replies
  • Nolan Scott
    May 27, 2007 at 9:56 am
    Using Photoshop CS / OSX 10.4.9
    First record your action / create new set and action.
    Then got to File / Automate / Batch /
    select your set and action / Source-folder and Destination-folder
    (you might like to create a new one) – click OK.
    (I am not quite sure if one can batch-export from TIFF to JPG)
    Cheers
    Nolan
  • Adolf Witzeling
    May 29, 2007 at 7:10 pm
    Hi Larry,
    In Photoshop you have to create the action first, that you want to “batch apply” (unless of course you want to use a preset).
    1: Make sure the action window (or action tab) is visible . In the action window on the upper right hand corner, click on the small black triangle and choose NEW ACTION.
    It’ll prompt you to name the new action. Give it a name that you later will remember.
    2: OPEN one picture from the folder that you want to batch process, and apply whatever you need to ( rotate, filters… etc).
    3: SAVE the picture.
    4: CLOSE the window.
    5: STOP RECORDING the action by clicking the black square at the bottom of the Action window.
    6: Go to FILE….AUTOMATE….BATCH. In the window that’ll come up choose your action,
    specify source and destination folder and click OK.
    Hope that helps.
    -Adi
