Activity › Forums › Adobe After Effects › automate a chain of events
  • automate a chain of events
    Posted by Nicolas Gamz on July 18, 2012 at 12:41 pm
    Hi, I have a big project in which I always do the same repetitive actions. I would like to create a script that, actioned by a shortcut, creates a composition with the selected footage with the same name and the same settings (as if I’d slipped the file on the icon of composition). Then he puts the composition and the file in a folder with the same name as the composition. Finally it paste effects. I never create a script before and I do not know how to do it.
    Nicolas Gamz replied 14 years, 2 months ago 3 Members · 5 Replies
  • Dan Fredley
    July 18, 2012 at 11:00 pm
    Create a preset and place the .ffx file into the same folder as the script
    Select at least one footage item in the project panel and run the script
    https://f1.creativecow.net/4416/createcompsaddeffectsjsx
  • Angelo Lorenzo
    July 18, 2012 at 11:01 pm
    You may find https://aenhancers.com/ a much better resource for learning scripting as well as requesting fairly simple scripts like what you’ve described.
    *EDIT* looks like someone has already helped you out.
    Angelo Lorenzo
    Fallen Empire – Digital Production Services
    RED transcoding, on-set DIT, and RED Epic rental services.
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Nicolas Gamz
    July 18, 2012 at 11:22 pm
    thanks for the links, there is a way to save my actions like in photoshop?
  • Dan Fredley
    July 19, 2012 at 1:13 am
    You can’t “record actions”, but you can save effect settings into a preset. In the timeline just select the effect AND all of the effect properties that you would like to save. Then go to Animation>Save Animation Preset and save it to the folder where you put the script. The run the script from the File>Scripts>Run Script menu item.
    More preset info:
    https://adobe.ly/NyFIZe
  • Nicolas Gamz
    July 19, 2012 at 11:46 am
    thanks a lot
