Activity › Forums › Adobe After Effects › auto white balance
Paul Docherty
July 22, 2020 at 4:35 pmI tried this, typed in the additional lines verbatim. Still getting the error “invalid numeric result (divide by zero?)”
This project works fine with my video until I change the video size for the replacement input. I performed Fit To Composition on the hidden layers to adjust for size. Was that not correct?
Paul Docherty
July 22, 2020 at 6:17 pmUpdate on this:
Maybe it’s an AE CC 2019 (v16.1.3) issue. I just tried loading the original project file without changing _anything_ but as soon as I click on the text layer I get the “invalid numeric result” error in the same place. Same error after typing in your non-zero fix. Same error if I delete the text layer, so likely it’s just a coincidence activating the text triggers the error.
BUT it appears to be working in AE CS6. So maybe I’m okay…
Chris Wright
July 23, 2020 at 3:16 amupdated for ae 2017 and minor bug fix division by zero
https://f1.creativecow.net/12087/auto-white-and-flicker-ae-cc2017-template?uploaded=file -
Ivelina Ivanova
January 4, 2021 at 3:03 pmnone of the links mentioned in this thread seem to work anymore 🙁
EDIT: I had the private webpage error but managed to fix it. ignore my reply
Craig Trayler
July 14, 2021 at 1:26 pmHi, how did you get the last link to work? Comes up error when I try it as is or removing the f1. at the start.
Chris Wright
August 10, 2021 at 2:45 pmAE CS6 autowhitebalance 1.0a.zip (division by zero bugfix, and luma matte, pre-converted down to cs6 for compability)
https://drive.google.com/file/d/1oJolQuEzQUrM14oOoHEHyiEaFoa04Sus/view?usp=sharing
