Activity › Forums › Adobe After Effects › auto white balance
auto white balance
Posted by Chris Wright on November 21, 2010 at 8:51 amI made a fully automatic white balance after effects project. it uses part of rebel cc then finds the color cast and automatically removes it. it also fixes cameras with auto white balance on changing too much in a shot.
ae cs3 aep
https://www.mediafire.com/?cn91hzp79q4cp4fIvelina Ivanova replied 5 years, 7 months ago 10 Members · 35 Replies -
Chris Wright
November 21, 2010 at 9:11 pmif you’d like to see how well it works, apply rebel cc to test_wb comp and apply wiggle(1,.2) to set grey. The white balance will go absolutely bananas, but the final comp will still work perfect. Which makes you wonder, why didn’t adobe make this plugin 10 years ago?
https://technicolorsoftware.hostzi.com/
Jim Arco
November 22, 2010 at 1:15 pmChris,
I continue to be impressed with the clever solutions you come up with to solve what seems like the very problem I am currently working with.
This one works amazingly well. I have to admit, I am having a bit of difficulty understanding exactly HOW it works. I am guessing there is some expression that refers to the ‘gg’ comp, but I haven’t found it yet.
In any case thanks for another great solution.
Jim
Any chance you could add a tool to even out the exposure variations as the camera’s auto exposure tries to track changing light levels?
Jim Arco
November 22, 2010 at 1:20 pm“….makes you wonder, why didn’t adobe make this plugin 10 years ago…”
I have never understood why there has never been a real simple “white balance” tool plugin OR
Why there is no “display the embedded timecode/date?”
…some patent/copyright issue maybe?
Chris Wright
November 22, 2010 at 6:44 pmit simply imagesamples the whole image, averages all the pixels and returns a 15% grey that gets put into a log lin function in the grey point. I’m currently working on an auto exposure. In the meantime, ae’s color stabilizer in the past worked great for me.
also, I wrote a mouse program that moves farther the faster you twitch your wrist. It saves me from carpel tunnel.
Chris Wright
November 22, 2010 at 10:53 pmI added an auto exposure in midtones brightness. It’s beta, but seems to work good. I am going to add frame smoothing to it after I figure out easing. until then, perhaps convert to keyframes and easy ease.
I replaced the download file so its updated.
Chris Wright
November 23, 2010 at 12:51 amanother fixed bug. it was double gammafying. also, I added overiding control sliders. it’s all 32bpc.
I replaced the download file again so its updated again.
Chris Wright
November 24, 2010 at 8:57 pmI would love to hear if my auto exposure is helpful or feedback on improving it.
also, I was looking at some really old footage and it doesn’t use gamma, it uses like huge blocks of black. That’s a new one to me.
and to your other question
“Why there is no “display the embedded timecode/date?”
https://forums.creativecow.net/thread/2/990824#990826https://technicolorsoftware.hostzi.com/
Chris Wright
November 25, 2010 at 5:29 amIf you have some really bad footage where the exposure or sun changes really big, use the new gamma clamp slider which clamps gamma and then turns on black point restore mode. Still fully automatic!
https://www.mediafire.com/?11pae00grg9rhhx
Jim Arco
November 25, 2010 at 2:38 pmDefinitely would benefit from some frame-smoothing. I tried it on some old VHS footage (shot in low light with an old camcorder, so the footage was …uhm, well, …junk!)
I would sometimes see frames that flashed or had significant color difference from the rest. My guess is this is due to noise in the video. You might want to try blurring the layer that is used for the ‘averaging.’
It is certainly going to save me a lot of time/effort. I’ll have a bit more time this weekend to really try this out and let you know what else I discover.
Jim Arco
November 25, 2010 at 2:45 pm“…it doesn’t use gamma, it uses like huge blocks of black…”
I’ve got some really old stuff – EIAJ, VHS, 3/4-inch, and even 1-inch, but I’ve never seen what you’re referring to. Can you post a sample somewhere?
Thanks for the timecode info. There have been third-party tools that would display or burn-in the file’s original time/date. But I never guessed that this was one of those places where there were “plenty of standards to choose from.”
